When I start my car, the Emergency Brake, Stability Control Warning lights, Trac Off (VSC) lights stay on?
175,000 MILES • 4 CYL • 2WD • AUTOMATIC
MESMITH27
I always release the emergency brake when driving, so what could the reason these lights are on?
Apr 7, 2023 at 5:28 AM
  • 55,758 POSTS
The first thing I would do is check the brake fluid and if low I would check the brake pads, if the fluid level is okay, I would run the codes for the ABS because it sounds like you have a wheel speed sensor that has gone out.
Here is a guide to show you how to get the codes:
https://www.2carpros.com/articles/anti-lock-system-testing-and-repair-abs
Here is how to change out the ABS wheel sensor in case you need it. Check out the images (below). Please let us know what happens.
Apr 8, 2023 at 4:30 AM
