Warning lights
68,000 MILES • 1.6L • 6 CYL • 4WD • AUTOMATIC
NICKSPOP56
All my warning lights on dashboard are on and then after awhile they go back to normal. This has happened a few times in last month.
Jun 20, 2019 at 11:08 AM
  • 110,248 POSTS
Welcome to 2CarPros.
Is there anything that seems to cause this? For example, a bump in the road, something being turned on, temperature or anything you can think of?
What I would first suggest is to start at the power source, the battery. Make sure the battery terminals are clean and tight. A loose or corroded connection can cause crazy things to happen.
If that isn't the issue, when the engine is running, slight jiggle the ignition key to see if there is a problem there.
Jun 21, 2019 at 2:51 PM
