warning lights
2007 FORD FIVE HUNDRED
150,000 MILES • AWD
TERRY APPLEGATE
changed wheel hub bearing on both sides on rear after doing this after driving down road for a mile or so the traction control light comes on the speedometer stops working and in the info center it says check braking system if you shut car off and restart it once again after a mile it happens again
Apr 8, 2017 at 3:15 AM
HMAC300
  • 48,601 POSTS
because of the bearing change you may have messed up a sensor for abs and when that happens it knocks off traction control as well. have it scanned for codes by amechanic see what comes up
Apr 8, 2017 at 5:02 AM
