VSC, 4hi, traction control and the ABS lights on
157,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
GILLY377
I have the truck listed above Crewmax limited. The VSC light and 4hi lights are flashing and the traction control light and the ABS lights are solid on. I can shut the truck off and they go away but after driving for 10 to 20 minutes they come back on.
Dec 13, 2019 at 4:47 AM
  • 110,248 POSTS
The indicators you have all seem related. Often times a vehicle speed sensor or wheel speed sensor can cause these issues.
We have two choices here. First and the easiest is to have the computer scanned to see what diagnostic trouble codes are stored. That should point us in the right direction. Or, you can start checking speed sensors to see if one has failed. The interesting thing is it takes 20 minutes of driving for the light to come back on. However, that is where we will have to start.
Here is a link that explains how to check wheel speed sensors:
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
Let me know what you find.
Dec 13, 2019 at 12:19 PM
GILLY377
Finally was able to get the code. Got a Innova 3100 code scanner for Christmas and the code is C0200, RF wheel speed sensor . Now I just need to see if it is the harness or the sensor. I already bought the left front and right front sensors from what you told me and from what I learned on the web. Hopefully I can get at it today but it's cold outside. Lol
Dec 28, 2019 at 2:58 AM
  • 110,248 POSTS
With today's vehicles, a scanner is worth its weight in gold. LOL
I don't know if you want to, but here is an easy test to confirm the sensor is bad:
Also, here is a link that shows in general how one is replaced:
https://www.2carpros.com/articles/how-to-replace-an-abs-wheel-speed-sensor
One last thing. I don't know if you need them, but here are the directions specific to your vehicle for replacing both front right and left sensors. I would only replace the bad one in this case, but that's up to you. The attached pictures correlate with the directions.
__________________________________________________________
2007 Toyota Truck Tundra 4WD V8-5.7L (3UR-FE)
Front Speed Sensor
Vehicle Sensors and Switches Sensors and Switches - Brakes and Traction Control Wheel Speed Sensor Service and Repair Removal and Replacement Front Speed Sensor
FRONT SPEED SENSOR
REMOVAL
1. DISCONNECT CABLE FROM NEGATIVE BATTERY TERMINAL
NOTE:
- After the ignition switch is turned OFF, the navigation system requires approximately 90 seconds to record various types of memory and settings. As a result, after turning the ignition switch OFF, wait 90 seconds or more before disconnecting the cable from the negative (-) battery terminal.
- Some systems need to be initialized after the cable is reconnected.
2. REMOVE FRONT WHEEL
3. REMOVE FRONT SKID CONTROL SENSOR WIRE LH
a. Disconnect the connector (labeled A) from the front speed sensor.
pic 1
b. Detach the 3 clips (labeled B) and remove the clamp bolt (labeled C).
pic 2
c. Disconnect the connector (labeled D).
d. Remove the 3 bolts (labeled E), 3 harness clamps(labeled F) and sensor wire.
4. REMOVE FRONT SPEED SENSOR LH
pic 3
a. Remove the hexagon socket head cap bolt (labeled A) and speed sensor (labeled B) from the knuckle.
5. REMOVE FRONT SKID CONTROL SENSOR CLAMP LH
a. Remove the bolt (labeled C) and skid control sensor clamp (labeled D) from the knuckle.
6. REMOVE FRONT SKID CONTROL SENSOR WIRE RH
pic 4
pic 5
d. Remove the connector (labeled D) from the skid control sensor clamp (labeled H).
e. Remove the 2 bolts (labeled E) and 2 harness clamps (labeled F).
f. Remove the bolt (labeled G) and skid control sensor clamp (labeled H).
7. REMOVE FRONT SPEED SENSOR RH
pic 6
8. REMOVE FRONT SKID CONTROL SENSOR CLAMP RH
INSTALLATION
1. INSTALL FRONT SKID CONTROL SENSOR CLAMP LH
pic 7
a. Install the skid control sensor clamp (labeled A) with the bolt (labeled B).
Torque: 13 N.m (127 kgf. cm, 9 ft.lbf)
NOTE: Install the bracket so that the rotation stopper (labeled C) touches the knuckle.
2. INSTALL FRONT SPEED SENSOR LH
a. Install the speed sensor (labeled D) with the hexagon socket head cap bolt (labeled E).
Torque: 11 N.m (107 kgf. cm, 8 ft.lbf)
NOTE:
- Make sure there are no pieces of iron or other foreign matter attached to the sensor tip part.
- While inserting the speed sensor into the knuckle hole, do not strike or damage the sensor tip part.
- After installing the speed sensor, make sure there is no clearance or foreign matter between the sensor stay part and the knuckle.
- Make sure there is no foreign matter attached to the magnetic rotor.
3. INSTALL FRONT SKID CONTROL SENSOR WIRE LH
pic 8
a. Connect the connector (labeled A).
b. Install the 3 harness clamps (labeled B) with the 3 bolts (labeled C).
NOTE:
- When installing the clamps, do not twist the wire harness.
- For clamps with rotation stoppers, make sure the rotation stopper touches the installation position.
pic 9
c. Install the harness clamp with the bolt (labeled D).
NOTE:
- When installing the clamp, do not twist the wire harness.
- Make sure the clamp's rotation stopper touches the installation position.
d. Attach the 3 clips (labeled E).
NOTE:
- When installing the clips, do not twist the wire harness.
- When installing the clips, securely insert them as shown in the illustration.
e. Connect the speed sensor connector (labeled F).
NOTE: Securely connect the connector.
4. INSTALL FRONT SKID CONTROL SENSOR CLAMP RH
pic 10
NOTE: Install the bracket so that the rotation stopper(labeled C) touches the knuckle.
5. INSTALL FRONT SPEED SENSOR RH
Torque: 11 N.m (107 kgf.cm, 8 ft.lbf)
NOTE:
6. INSTALL FRONT SKID CONTROL SENSOR WIRE RH
pic 11
Torque: for Bolt B 5.0 N.m (51 kgf. cm, 44 in.lbf)
b. Install the connector (labeled C) with connect the connector (labeled C).
c. Install the 2 harness clamps (labeled D) with the 2 bolts (labeled E).
Torque: for Bolt E 13 N.m (127 kgf.cm, 9 ft.lbf)
NOTE:
pic 12
d. Install the harness clamp with the bolt (labeled E).
Torque: 13 N.m (127 kgf.cm, 9 ft.lbf)
NOTE:
e. Attach the 3 clips (labeled F).
NOTE:
f. Connect the speed sensor connector (labeled G).
7. INSTALL FRONT WHEEL
Torque: for Aluminum Wheel 131 N.m (1336 kgf. cm, 97 ft.lbf)
for Steel Wheel 209 N.m (2131 kgf.cm, 154 ft.lbf)
8. CONNECT CABLE TO NEGATIVE BATTERY TERMINAL
NOTE: Some systems need to be initialized after the cable is reconnected.
9. CHECK SPEED SENSOR SIGNAL
a. Check the speed sensor signal.
If you get a chance, let me know how this works out for you. Also, have a great new year!!!
Dec 28, 2019 at 11:27 AM
