Brake light, battery light and vacuum light all on?
125,000 MILES • 3.9L • TURBO • AUTOMATIC • DIESEL
MERITSVC
Brake light, battery light and vacuum light all on. blower motor seemed to stop at the same time.
Blower motor seems to have voltage. alternator has been replaced. 14.4 volts to batteries from alternator.
local shop could not find source of problem.
thanks,
Gary
May 29, 2026 at 1:40 PM
  • 55,770 POSTS
Hi Gary, I would check the fuses and fusible links/main system fuses in the truck first, this video will help you
https://www.youtube.com/watch?v=G-xNK79Wa-w
Please go over this guide as well
https://www.2carpros.com/articles/how-to-check-a-car-fuse/
Check the main fuse panel fuses first. Let me know how it goes.
May 31, 2026 at 9:27 AM
