Warning lights
45 MILES • 1.4L • 4WD • MANUAL
JACKIEKASSIM70
I have to dip the clutch to start my car the clutch weren’t fully dipped due to my footwear so car didn’t start when I fully pressed the clutch down car started. after that happened all my warning lights came on. the car is driving as normal just all the warning lights come on after that happened with my clutch. Because if I don’t dip the clutch fully the car won’t start.
Dec 25, 2020 at 4:41 PM
I am not sure what you mean the lights all come on now after you didn't get the vehicle starter.
Does the vehicle start like normal if you depress the clutch fully? Do the lights just stay on all the time now? Maybe get a video of what is happening and that will explain better what is happening so that we can get on the same page.
Also, if the lights are staying on can you check for codes? Here is a guide that will help:
Let us know about this info so that we can assist as best as possible. We don't have a manual on this vehicle as it is not offered in the USA but I am sure we can help figure something out. Thanks
Dec 26, 2020 at 10:05 AM
