Multiple warning lights are on
300,000 MILES
PAMELA49
check engine, battery, oil, and tire pressure lights are on. brakes are screeching.
Jan 15, 2021 at 4:37 PM
I suspect you have multiple issues so let's tackle the check engine light here and then if that does not resolve some of the others, we are going to need to get a new post started for them. The brakes I am sure is not related so if you want to go ahead and get new post started for this, that would be great. We just need to keep each post to one topic so that others that have the same issue as you, can find the solutions.
As for the check engine light, we need to start with checking the codes and find out what is causing it to come on.
Once we know the codes we can go from there. I suspect you will have some codes for the check engine light and you may have a code that will tell us what the tire light is on for.
Let us know and we can go from there. Thanks
Jan 16, 2021 at 11:09 AM
