Today's vehicles are extremely sensitive when it comes to voltage. If the alternator isn't producing, it can cause all kinds of crazy things.
So, how often does this happen? I ask because we need to check if the alternator is failing. To check, you will need a voltmeter or multimeter. It's really easy to do but should be done when the light is on.
Here is a link that explains how it's done:
Try this and let me know the results. Also, let me know if you have other questions.
Aug 7, 2022 at 4:16 PM
