Warm Idle about 650 RPM but act like it will stall
2002 SATURN SL1
123,000 MILES • 1.9L • 4 CYL • FWD • AUTOMATIC
PEPI-V
  • 9 POSTS
Saturntech9,
I have seen a lot of your responses to issues, so here is one for you. My daughters car, once warm likes to idle about 650 in drive. When we come to a stop and the idle starts coming down, it will drop down to almost 600 then shudder and back up to 650. It has new plugs (NGK's) and plug wires, new idle air control valve, throttle body cleaned and just recently a new ECT. The connector has been replaced before and looks to be good.
Thanks
Sep 10, 2017 at 12:10 AM
SATURNTECH9
  • 30,869 POSTS
Try this let it idle in park then get some carburetor spray or brake cleaner insert the straw into the nozzle and spray around where the intake manifold meets the head by the power steering pump area. if the engine stumbles or shuts off or rpm's increase then you you have a leaking intake manifold gasket, very common on those cars.
Sep 10, 2017 at 10:02 AM
PEPI-V
  • 9 POSTS
Actually, I thought about that too and tried that, no change in rpm's.
Sep 10, 2017 at 10:09 AM
SATURNTECH9
  • 30,869 POSTS
There is a short PCV hose that goes from the intake manifold to the valve cover, see if it is clasped or has holes in it?
Sep 10, 2017 at 10:24 AM
PEPI-V
  • 9 POSTS
I will double check that, but I tried spraying carburetor cleaner all over the engine thinking a bad vacuum line, but did not notice any rpm changes.
Sep 10, 2017 at 10:26 AM
SATURNTECH9
  • 30,869 POSTS
Have you checked for codes in the computer yet?
Sep 10, 2017 at 10:33 AM
PEPI-V
  • 9 POSTS
Yes I have, no codes. I should add, that we bought this car used a couple of months ago and the guy had replaced the cylinder head because something broke on the original one I thought he said for the cam. Otherwise the car runs great, just the idle dropping to almost killing after warming up If we have the AC on, it kicks the rpm's up a couple hundred and we have no problems at all. Turn AC off and the idle drops below 600 before it comes back up. Almost like the IAC is reacting slow. I could try another IAC, even though this one was new.
Sep 10, 2017 at 10:58 AM
SATURNTECH9
  • 30,869 POSTS
This is for sure a SL1 not a L model Saturn?
Sep 10, 2017 at 11:44 AM
PEPI-V
  • 9 POSTS
Yes, SL1.
Sep 10, 2017 at 11:52 AM
SATURNTECH9
  • 30,869 POSTS
Okay, I have seen the four cylinder engine in the L 200 idle too slow and with the A/C on idle fine. Caused by needing a updated engine control module software.
Sep 10, 2017 at 12:05 PM
PEPI-V
  • 9 POSTS
I suppose anything is possible, but I am wondering if the guy we bought the car from ever changed the ECM and used one from a L series.
Sep 10, 2017 at 8:40 PM
SATURNTECH9
  • 30,869 POSTS
That would not plug in or work on that car. you could have a bad or carboned up idle air control valve, it is screwed to your throttle body. you could try lightly tapping on the idle air control and see if the rpm's rise to the normal level.
Sep 11, 2017 at 2:16 PM
PEPI-V
  • 9 POSTS
Okay, I did not get a chance yesterday to check anything, but I will try today. Thanks.
Sep 11, 2017 at 9:00 PM
PEPI-V
  • 9 POSTS
So it has been a while since I have posted anything and that kind of annoys me when I see people with problems and suggested answers and they never return for an update to let others know what worked or didn't work. So enough with my ranting and here we go.
I checked everything over and made sure no vacuum leaks. Couldn't find anything. As my daughter drove the car more and it started happening less and less. She never told me it did ever die on her. I don;t know if it just took a while for the new IAC to"sync" up with computer and find the right position or speed to which it reacted, but seemed to stop having issues. We have since sold the vehicle because we no longer needed it.
Saturntech9...Thanks for all your help and suggestions.
Feb 2, 2018 at 5:23 PM
SATURNTECH9
  • 30,869 POSTS
Your welcome the idle air control valve sets itself as soon as you start it after replacing it.
Feb 2, 2018 at 5:33 PM
PEPI-V
  • 9 POSTS
I know it should, but just seemed weird that the more we drove it the better it got. And by more we drove it, I mean almost over 1,000 miles.
Feb 2, 2018 at 5:34 PM
SATURNTECH9
  • 30,869 POSTS
Maybe you had water in the fuel tank and worked itself out.Thsts the worst and sometimes a pain to pin point that's what it is.
Feb 3, 2018 at 12:52 AM
