engine not starting
170,000 MILES • 6 CYL • 2WD • MANUAL
CREATURE0911
Turn the key and nothing, but batteries not drained, but can push start it fires up, then you can shut it off and starts with key for a few times.
Oct 15, 2017 at 5:40 AM
  • 55,766 POSTS
When you turn the key to start the engine does make any sounds and is the security light flashing?
Cheers, Ken
Oct 16, 2017 at 9:45 AM
STEVE W.
  • 15,418 POSTS
Check the wiring at the starter solenoid for loose/corrosion. The lack of initial action sounds like a poor connection that engine heat/vibration "fix" for a few tries.
Oct 16, 2017 at 2:00 PM
