Want to know what the ohms would be on a ground A/C relay?
1998 CHEVROLET SILVERADO
198,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
DWAYNEB
I replaced the compressor the dryer, the low-pressure switch, the high-pressure switch, and the climate control inside the truck. The relay checked all the fuses. All is good, but I’m still not getting power to the A/C compressor.
1998C 10 full size Chevrolet pickup.
May 12, 2025 at 3:35 PM
  • 55,224 POSTS
The ohms for the ground to the relay should be close to "0". What problem are you having so I can help?
May 14, 2025 at 4:22 AM
