Input speed sensor replacement
150,000 MILES • 2.0L • 4 CYL
JOHN.COUTURE
Need to know the location of the input speed sensor on the transmission.
Apr 18, 2019 at 7:45 AM
Good afternoon,
They call it a turbine shaft speed sensor. Check out the images (Below). Please let us know if you need anything else to get the problem fixed.
Apr 18, 2019 at 8:19 AM
JOHN.COUTURE
Input sensor on a transmission, transmission won't shift into high gear.
Apr 18, 2019 at 10:02 AM
JOHN.COUTURE
I researched this found it could be the problem.
Apr 18, 2019 at 10:03 AM
Again, do you have a code?
If the input speed sensor was the issue it would not shift as that signal is critical for shifting. the location is in the diagrams below.
If you have an advanced scan tool you can monitor the sensor readings.
NPUT/TURBINE SPEED SENSOR REMOVAL/INSTALLATION
1. Remove the battery duct and battery cover.
2. Disconnect the negative battery cable.
3. Remove the battery, battery box and battery tray.
4. Disconnect the input/turbine speed sensor connector.
5. Remove the input/turbine speed sensor.
6. Apply ATF to a new O-ring and install it on a new input/turbine speed sensor.
7. Install the input/turbine speed sensor.
Tightening torque 8 - 11 Nm (82 - 112 kgf-cm, 71 - 97 inch lbs.)
8. Connect the input/turbine speed sensor connector.
9. Install the battery, battery box and battery tray.
10. Connect the negative battery cable.
11. Install the battery duct and battery cover.
Testing
INPUT/TURBINE SPEED SENSOR INSPECTION
Caution: Water or foreign material entering the connector can cause a poor connection or corrosion. Be sure not to drop water or foreign material on the connector when disconnecting it.
5. Measure the resistance between the input/turbine speed sensor terminals. If there is any malfunction, replace the input/ turbine speed sensor.
Resistance 250 - 600 ohms (ATF temperature: 40 - 160°C (-40 - 320°F))
6. Connect the input/turbine speed sensor connector.
7. Install the battery, battery box and battery tray.
8. Connect the negative battery cable.
9. Install the battery duct and battery cover.
Apr 18, 2019 at 10:10 AM
JOHN.COUTURE
Seems to be helpful, but I never heard it called a turbine speed sensor before, thank you so I'll try I'll try this.
Apr 19, 2019 at 12:16 PM
You are welcome.
Always glad to help.
Apr 19, 2019 at 9:24 PM
