Want start spark plug fires one time turn alarm on an off an plug fires again only ounces
2003 NISSAN ALTIMA
193,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
KEVINMCKINNIE
Cylinder only fires one time turn alarm on an off an turn the key an cylinder will fire one time an no more I changed crank sensor I changed cam sensor I changed injector rack I checked all the all the fuses
Jan 16, 2014 at 7:17 AM
HMAC300
  • 48,601 POSTS
try resetting security system then get is scanned for codes.
Jan 16, 2014 at 11:58 PM
KEVINMCKINNIE
How do u reset security system on a 2002 altima
Jan 17, 2014 at 2:09 AM
HMAC300
  • 48,601 POSTS
We get this problem this time of year remote keyless entry gets used a lot more and the buttons get dammaged. Try removing the battery on your remote first. Go back to key until you get another remote(s). Turn the lock to unlock and hold it there one to two seconds to disarm the security system. Trunk lock will also disarm the security system if the drivers door key switch is not working.
Jan 17, 2014 at 4:03 AM
