Engine cranks but does not start?
140,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
ROBBY163
I've replaced almost everything; starter, fuel pump, plugs, battery 02 sensor, cam position sensor, and timing belt. I hope i timed it correctly. It acts like it's not getting fuel. I've replaced the fuel rail and injectors, I've sprayed starter fluid in throttle body.
Nov 3, 2022 at 6:29 AM
  • 110,248 POSTS
Did the engine start for a few seconds using starting fluid? If it didn't, it sounds like there is no spark at the plugs. Have you checked for spark? If not, here is a link that explains how it's done:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
Also, if you could record it cranking and upload it for me to hear, it would be helpful.
Nov 3, 2022 at 6:55 AM
