Good evening.
With the key on, check for battery voltage to the positive side of the coil.
Then, if you have a test light, put it on the negative side of the coil. the light should light. then crank the engine and see if the test light flashes. that will tell you if the module is working.
Mar 6, 2018 at 7:13 AM
