Will not start
150,000 MILES • 2.9L • 4 CYL • 4WD • AUTOMATIC
CDAWSON
Shut off while driving and it hasn't started back up.
Sep 2, 2019 at 11:29 AM
  • 110,248 POSTS
Welcome to 2CarPros.
When an engine refuses to start, most often it is a fuel related issue or ignition related. Take a look through this link:
The easiest thing to do is see if it starts for a couple seconds using starting fluid. If it does, then we know if is a fuel related issue. If it doesn't, then chances are it is ignition related.
Here are links that explain how to check fuel pressure and how to check for ignition spark:
Do these things and let me know what you find. Also, let me know if you have other questions.
Sep 2, 2019 at 1:26 PM
