Vy supercharged Holden commodore fires but won't start
2003 HOLDEN CALAIS
160,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
OLEUM CHIN
car tries to fire but won't start I have replaced plugs coil packs ignighter spark plugs fuel pump crank and cam sensors tried a airflow meter off a running car when car fires it sometimes runs for a couple of seconds but very rough almost like timing is out if I spray either down intake it runs smoothe for five to ten seconds at my wits end don't know what else to try Iv had it scanned but no faults come up thank you so much if u can help
Sep 8, 2015 at 6:23 PM
  • 31,937 POSTS
Have you replaced the fuel filter and check the rail pressure, you also may want to get the injectors serviced, there are inline filters in the injectors, if you have a fuel problem, the injectors can have poor flow and spray pattern, if the car will run better with starter fluid down the throttle body I would be inclined to look here next.
Sep 8, 2015 at 6:54 PM
