VW Codes: P17C500, B109C15?
75,000 MILES • 2.0L • 4 CYL • 4WD • AUTOMATIC
ANTHONYGRIMM
These are the codes on my mother's car. I can't seem to find much about them online. Any help would be appreciated!
Apr 8, 2026 at 9:42 AM
  • 55,694 POSTS
Here are what these codes mean, can I ask what kind of issues are you having?
P17C500 - gear selector / selector lever implausible signal. On VW scan references, P17C5 is tied to the selector lever signal being invalid or not matching what the transmission expects.
B109C15 - air distribution flap motor position sensor open circuit / short to B+. That is an HVAC/climate-control fault, usually involving the mode-door actuator or its feedback circuit.
So these are two different systems with two different repairs. We can work on the first code in this thread but please start a new thread for the second code. For the P17C500 code I would replace the gear range sensor which is a common failure. Check out the images (below). Let us know how it goes
Apr 8, 2026 at 11:48 PM
