Codes P0300, P0302, VVT monitor bank 1 failure and multiple cylinders misfire detected?
2011 SKODA OCTAVIA
114,000 MILES • 1.8L • 2WD • MANUAL
KRISH1203
Recently got the camshaft sensor changed followed by timing chain and valves replaced as it had jumped 4 teeth. Everything was looking fine until I added 1 liter of oil as the oil in the dipstick was just at the bottom. When I accelerated from 1,800 to 2,000 RPMs, it was not smooth, and it was jerking. Now I have the check engine light on with codes P0300 and P0302. When i ran the live diagnostics, i got VVT bank 1 monitor fail. What could have been wrong? Was I wrong to add oil? My car used to burn a lot of oil and i had to add at least 1 l after 700 miles.
Aug 17, 2023 at 5:52 PM
  • 55,423 POSTS
The fact that the timing chain jumped 4 teeth may have bent a valve. To be sure let's do a compression test, I don't think the type of engine oil will matter.
Start with cylinder #2. Please go over these guides and get back to us.
Aug 18, 2023 at 4:52 AM
KRISH1203
Many thanks for your response, Ken. I replaced all the four spark plugs and there was no misfiring. In fact, the valves were changed along with the timing chain, so I didn't do compression test. All my searches lead to 1. Spark Plug, 2. Coil pack and 3. Valves. I started with the spark plug and it worked. One spark plug was looking bad with a lot of black deposit on it compared to the other three. Suspect Oil Fouling. I believe my Skoda burns a lot of oil and this should be the cause. Should I look further into the oil leak, or can I leave it here? Probably I will leave it here and buy a new car, I don't want to spend another fortune.
Aug 22, 2023 at 2:38 PM
  • 55,423 POSTS
It does sound like one cylinder has low compression, you can use this guide to confirm if needed.
Please go over this guide and get back to us.
Aug 24, 2023 at 3:44 AM
