VSS location
141,000 MILES • 3.7L • 6 CYL • 4WD • AUTOMATIC
DAVE390
I have replaced two s sensors one should have been the output and one should have been input, but I still have an engine light on P0500 code. could this be and the transmission control module?
Feb 19, 2018 at 4:21 AM
Good afternoon.
Do you have ABS with your truck?
Feb 19, 2018 at 4:52 AM
DAVE390
Yes.
Feb 19, 2018 at 5:17 AM
Okay, the vehicle speed sensor that sends a signal to the PCM is the ABS sensor on the rear differential. it uses the ABS signal for a sign of vehicle speed.
Check the connector for any damage or spread pins.
Feb 19, 2018 at 5:20 AM
