VSS code P0501
220,000 MILES • 2.2L • 4 CYL • FWD • AUTOMATIC
BCMULLEN95
  • 249 POSTS
I have the code P0501. Will this code cause the transmission to act up and not shift properly? Will this code cause the speedometer to not work?
Jul 23, 2016 at 8:04 AM
HMAC300
  • 48,601 POSTS
it will do both if it is not working properly , keep in mind it may not be the VSS and could be a short in wiring as well.
Jul 23, 2016 at 9:45 AM
BCMULLEN95
  • 249 POSTS
What can I door to narrow down if it is the VSS?
Jul 23, 2016 at 9:47 AM
HMAC300
  • 48,601 POSTS
replace the VSS and if that does not fix it then you will have to check for shorted wire with an ohm meter.
Jul 23, 2016 at 10:19 AM
BCMULLEN95
  • 249 POSTS
What would be the voltage reading I would need for the VSS?
Jul 23, 2016 at 10:50 AM
HMAC300
  • 48,601 POSTS
0-5 volts.
Jul 24, 2016 at 1:11 AM
BCMULLEN95
  • 249 POSTS
I replaced the VSS it drove for a little while with out issue. Now the code P0715 is showing. What are my next steps to rule out mechanical issues.
Jul 24, 2016 at 10:21 AM
HMAC300
  • 48,601 POSTS
that is main shaft speed sensor check resistance per instructions sent, but i would bet it is a mechanical issue inside transmission.
Jul 24, 2016 at 11:45 PM
BCMULLEN95
  • 249 POSTS
Replace the main shaft speed sensor and it is drivable for now. I will be getting it rebuilt soon. Thanks for your help.
Aug 14, 2016 at 2:46 AM
