Where is the VSS located exactly?
2003 FORD TAURUS
260,000 MILES • 3.6L • V6 • 2WD • AUTOMATIC
JAMES904
Sep 16, 2020 at 12:37 AM
Good morning,
I attached pictures of the location of the speed sensor for you.
What is the issue that leads you to replace this sensor?
Sep 16, 2020 at 12:48 AM
JAMES904
With the pictures you provided is that under the transmission?
Sep 16, 2020 at 1:19 AM
Okay, are there any codes set in the system?
The stuttering is a known issue. That is torque converter shutter. To verify, there is an additive at a parts store you can add to the fluid. Drive it for about 25 miles. If the stutter stops, it is the clutches in the torque converter that is the issue and the torque converter needs to be replaced.
When was the last time you change the fluid and filter?
Sep 16, 2020 at 1:21 AM
JAMES904
The fluids and filter has never been changed. That's the plan for the weekend.
Sep 16, 2020 at 1:22 AM
