VSC Trac and VSC Trac off lights on?
2004 TOYOTA 4RUNNER
248,000 MILES • 4.7L • V8 • 4WD • AUTOMATIC
CGOETZ1984
  • 16 POSTS
I recently had my check engine light VSC Trac and VSC trac off lights on on my dash. I recently replace the O2 sensor and the check engine light went off, but the VSC Trac and VSC Tac off lights are stuck on? Any ideas why that would be? Thanks in advance for any help.
Nov 10, 2020 at 10:06 PM
More then likely this is a wheel speed sensor issue. However, we need to check for codes and make sure. Here is a couple guides that will help:
https://www.youtube.com/watch?v=rTtAnsOlZU4
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
Let us know what the codes are and we can go from there. Thanks
Nov 10, 2020 at 10:57 PM
