2004 Toyota 4Runner Propane Fuel
2004 TOYOTA 4RUNNER
51,000 MILES • V8 • 2WD • AUTOMATIC
WILLIAM HISAW
i recently converted from gasoline to propane/gas, it now uses both. The problem i'm having, after installation i'm getting warning lights for i.e.; pos trac off, vsc off, check engine, all are lighted. I reset the computer the lights went off for a short period of time and are lit again. i need the pos trac to function because of conditions where i use the vehicle. is there a solution to have pos trac while using propane?
May 9, 2008 at 11:54 PM
2CARPRO JACK
  • 11,533 POSTS
Need to Have the PCM scanned for the codes, this will help in diagnosing the problem with the TRAC and the engine management.
May 10, 2008 at 1:45 AM
WILLIAM HISAW
rescanned the pcm codes, the pcm does not recognize the propane fuel, and thus shuts down engine management resulting in the warning lights. my question is; is there a solution?
May 10, 2008 at 7:18 AM
2CARPRO JACK
  • 11,533 POSTS
Might want to try Google, are a few sites I found that talk about propane
May 11, 2008 at 1:49 AM
