Check engine, VSC and track control lights are on and flashing with code p0303
188,000 MILES • 4 CYL • AUTOMATIC
DILLIGAF13
Misfire in cylinder 3. why would this cause the VSC light and trac to be on?
Jan 6, 2022 at 5:06 AM
Good afternoon,
It will not. The code is for a misfire for a number 3 cylinder. I would start by checking the compression.
Your scan tool cannot read the other code. You need a more advanced scan tool to read the codes for the ABS system.
Jan 6, 2022 at 5:29 AM
