Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Pontiac
Vibe
Trouble Codes
P Codes (Powertrain)
P0300 - P0399
P0303
Check engine, VSC and track control lights are on and flashing with code p0303
2009 PONTIAC VIBE
188,000 MILES • 4 CYL • AUTOMATIC
DILLIGAF13
MEMBER
1 POST
Misfire in cylinder 3. why would this cause the VSC light and trac to be on?
Jan 6, 2022 at 5:06 AM
Experienced Mechanic
Good afternoon,
It will not. The code is for a misfire for a number 3 cylinder. I would start by checking the compression.
Your scan tool cannot read the other code. You need a more advanced scan tool to read the codes for the ABS system.
Jan 6, 2022 at 5:29 AM
Add image or video
Ask a new question
Check engine light
Engine stalls while driving
