Vsc and engine light are on.
162,000 MILES • 4WD • AUTOMATIC
WHEEZIE1
Just purchased the car for my daughter. Car fax showed very detailed maintainence records so I'm pretty sure the car has been well cared for. That said the vsc and check engine light came on. We took to a local shop and a small hose behind the filter had come loose. The mechanic put the hose back on reset the computer and the lights went off. After 500 miles and many engine starts, the vsc and check engine light came back on. Any thoughts? Of note it was raining both times it can on. is there any coincidence? Thanks in advance for any help.
Nov 15, 2015 at 1:25 AM
what were the codes??? were they the same as before??? there are over 1500 possible codes for failures.
Nov 15, 2015 at 2:19 AM
WHEEZIE1
Roy, I think the code was p0171 but not sure. Will get it read again. Best, Louise
Nov 15, 2015 at 3:12 AM
was that the same as before??
Nov 15, 2015 at 3:23 AM
WHEEZIE1
I haven't had it checked after the second time. I'll do so tomorrow and get back to you. Thanks for your help.
Nov 15, 2015 at 7:58 AM
