VSC and check engine light turned on
195,000 MILES • 3.7L • V6 • 2WD • AUTOMATIC
JRGORDON
Also the engine seems to be running rough at idle and in the different gears. What's the problem?
Oct 20, 2019 at 11:32 AM
  • 55,748 POSTS
We will handle the warning light problem on this thread you will need to start a new question for the engine issue. These lights come on usually for a wheel speed sensor that is out. To be sure lets run a scan on the system to find out which one is the problem. here is a video to help us get started:
https://youtu.be/rTtAnsOlZU4
You can get a reader from Amazon for about $35.00 Please run down this guide and report back.
Oct 22, 2019 at 6:19 AM
