Vsa with exclamation mark
228,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
LOSTONIT
Hi, hoping you can help again.
07 to type s message came up stating issue with vsa system. I scanned the car
And no codes at all. No check engine light. Just the message. I can activate by pressing the vsa button or turn it off
However the exclamation mark is still
Inside the triangle. Any and all help
Would be greatly appreciated.
Thank you
Jun 16, 2021 at 6:26 AM
If these lights are on then there should be some codes but I suspect they are ABS codes and not all scanners will pick those up.
More than likely you have an issue with a wheel speed sensor or steering angle sensor or even an ABS module.
Here is a guide that will help with retrieving this:
https://www.youtube.com/watch?v=rTtAnsOlZU4
https://www.2carpros.com/articles/abs-warning-light-on-easy-repair-guide
Once we know what codes are turning this on we can better diagnose this but here is a guide that will give you an idea how how to test wheel speed sensors if that turns out to be the issue:
https://www.2carpros.com/articles/how-to-replace-an-abs-wheel-speed-sensor
Let me know what questions you have and we can go from there. Thanks
Jun 17, 2021 at 11:57 PM
