The VSA light wont reset. Van running normal. What are usual causes and ball park estimate of dealer charges?
Oct 8, 2016 at 9:12 AM
JIS001
✓Experienced Mechanic
How are you trying to reset the light? To start with, we would need the code for the ABS system to get an idea as to what is going on.
Oct 8, 2016 at 1:29 PM
RENEE L
MEMBER
Hi JAMESCHARLTON,
Because this is an ABS issue your car needs to be scanned with a professional grade scanner to open the ABS and retrieve any codes stored. Most professional mechanics will have this type of scanner. Once you have the codes please return to the site so we can further assist you. Thank you for visiting 2CarPros.
