ABS failure/not working. Is it safe to drive? Will the wheels lock up?
Nov 24, 2023 at 9:46 PM
✓Experienced Mechanic
Yes, with the ABS/VSA warning light on the wheels will lock up. We need to scan the system because it sounds like you have a wheel speed sensor that is not working, which is common.
Here is a guide and a video to show you how to get the codes:
