attempting to remove the brake booster
39,000 MILES • 6 CYL • AWD • AUTOMATIC
STEFAN PAPADOPOULOS
upon attempting to remove the brake booster by removing the nuts, and in fact, did not budge. what am i missing ?
Mar 16, 2008 at 10:24 PM
  • 110,244 POSTS
Replacing the vacuum brake booster isn't too hard to complete. However, you will need to first remove the brake master cylinder first. The worst part of the job is unbolting the booster. It is done from under the dash on the driver's side. It is tight.
If you look at the attached pics below, they include the directions and pictures specific to your vehicle for removal and replacement. Follow them to replace the brake booster.
I hope this helps. Let me know if you have other questions.
Mar 29, 2021 at 12:58 PM
