2006 Volvo XC90 cabin air filter
2006 VOLVO XC90
53,000 MILES • 6 CYL • FWD • AUTOMATIC
LEE MESSENGER
  • 7 POSTS
how do i change the cabin air filter ? i cant find any info in the manuel.
Dec 20, 2008 at 10:53 AM
IMPALASS
  • 3,112 POSTS
Hello - I have attached the info
https://images.2carpros.com/forum/automotive_pictures/248015_1_123.jpg
Located right side passenger compartment under soundproofing panel. Service and Repair Notes Air cleaner passenger compartment, replacing Removing the passenger compartment air cleaner (ACL)
https://images.2carpros.com/forum/automotive_pictures/248015_2_80.jpg
Remove: the soundproofing panel. the screws for the cover the cover. Pull the air cleaner (ACL) downwards/away. Installing the passenger compartment air cleaner (ACL)
https://images.2carpros.com/forum/automotive_pictures/248015_3_57.jpg
Install the air cleaner (ACL). There are 2 alternative positions for the air cleaner (ACL). See the illustration. The pollen filter (standard) must be installed in the smaller compartment (1). The multi filter (cars with an air quality sensor) must be installed in the wider compartment (2). NOTE: Install either the pollen filter or the multi filter. Both filters must not be together. Install: the screws. The front left screw must not be tightened to more than 0.8 Nm the soundproofing panel.
Dec 20, 2008 at 4:26 PM
LEE MESSENGER
  • 7 POSTS
I DONT KNOW WHERE THE SOUNDPROOFING PANEL IS LOCATED AND HOW TO REMOVE IT. THANKS
Dec 21, 2008 at 2:49 AM
IMPALASS
  • 3,112 POSTS
Hello –
As it states: “Located right side passenger compartment under soundproofing panel.”
It is on the passenger side, look under the dash….I don’t have pic of that….but there should be a panel that covers the bottom of the dash above where the passengers feet go. It is probably held up by screws or clips of some type.
Remove them and the panel and then look for the bottom of the filter panel per the pic.
Dec 21, 2008 at 4:28 AM
JIS001
  • 3,412 POSTS
The panel is located under the glove box and is held by 2 25torque screws.
Mar 29, 2009 at 10:19 AM
IMPALASS
  • 3,112 POSTS
Hello - Thanks for the info JIS001 Lee Messenger - Also, it looks like you may have some recalls on your vehicle. The dealer may fix these for free. Please contact the dealer service department, give them the VIN number of your car and have them check on these to see if they apply to you.
https://images.2carpros.com/forum/automotive_pictures/248015_Recalls_28.jpg
Mar 29, 2009 at 10:29 AM
