Recently I had to remove the second row middle seat to remove debris that was causing the seat not to raise. Upon reinstalling the seat (including plugging in the underseat wiring connection) the SRS warning light came on when I started the vehicle. I have attempted to clear the codes using a standard over the counter code reader as well as disconnecting the battery. The SRS warning code still appears. I have double checked the plug under the seat and it is firmly connected.
My closest Volvo service is 3 hours away. Can I do anything else to clear this code myself?
Oct 3, 2010 at 11:09 AM
