Two days ago my radio would not work, then worked but when I turned off the key the radio stayed on I had to manually turn off. Then next day while driving my entire dashboard went out, lights gauges everything but I did not loose power with engine. I turned off engine then turned back on and my message board showed "SRS service urgent" and my dash lit back up again. The little symbol for airbag is lit up also. My controls to turn the station and volume also won't work for my radio at all.
Sep 23, 2009 at 1:02 PM
