2005 Volvo XC90 Rear Brakes
65,000 MILES • V8 • AWD • AUTOMATIC
PHILYM
I took my car into a national brake repair franchise to get an estimate on replacing the pads and turning the rotors on the rear wheels. I was told by the manager that on my particular car the rotors had to be replaced. Was he correct?
Thanks
Jun 21, 2008 at 4:37 AM
JEFF LYDIC
  • 13 POSTS
Volvo does not recommend resurfacing rotors as it can lead to brake squeek, improper pad wear and vibrations. Volvo has two min. replacement specs. One replacement spec is a recommended min thickness with brake pad replacement. And the other is the actual min. specs the rotors can be at. Volvo does this because if the rotors reach a certain specs when replacing the pads, the rotors can fall below specs before the next pad replacement.
Apr 1, 2021 at 11:45 AM
