2005 Volvo XC90 Fog Lights
90,000 MILES • 6 CYL • FWD • AUTOMATIC
EROWLAND
How do you replace a fog light lense?
How do you replace a fog light bulb?
Oct 1, 2009 at 10:52 PM
JIS001
  • 3,412 POSTS
The only way to replace the fog lamp lense is to replace the whole fog lamp assembly. If you need to replace the bulb then just unplug the connector and twist off the socket to replace the bulb.
Oct 2, 2009 at 8:09 PM
EROWLAND
Thanks for the information. Just ordered the full assembly. Looks pretty easy to install. Any special I need to look out for?
Oct 4, 2009 at 12:33 PM
JIS001
  • 3,412 POSTS
No just 3 screws to remove. You will need a torque 25 screwdriver or socket with ratchet. One of the screws may be hard to get at but I usually have the vehicle up in the air on a hoist so it is a little easier standing up? Good luck.
Oct 4, 2009 at 3:42 PM
