car just lost power and stop running
104,535 MILES • 4 CYL • 4WD • AUTOMATIC
EDDY RODRIGUES
I went over a big piece of tire on the road. The car just lost power and stop running. Is there any inhibitor switch for the fuel system? When I spray fluid into the intake system the car will running.
May 11, 2010 at 11:43 PM
JIS001
  • 3,412 POSTS
This sounds like the crankshaft angle sensor or the fuel pump has gone out, when you turn the key to the on position without cranking the engine over can you hear the fuel pump run in the tank for 5 seconds? These guides should help us fix it.
https://youtu.be/dCjmRL3p4Cs
and
Also, lets run the codes to see what come up.
Apr 7, 2019 at 2:00 AM
EDDY RODRIGUES
It was the crankshaft sensor thank you
