2004 Volvo XC90 When I press the gas the car makes a loud n
2004 VOLVO XC90
80,000 MILES • 6 CYL • AWD • AUTOMATIC
LAYELZOF
When i press on the gas or go fast seems like theres a loud noise coming from under the hood. When I stop pressing the gas it stops.
Feb 12, 2010 at 1:49 AM
JIS001
  • 3,412 POSTS
Has the check engine light come on yet? If it has what are the codes? You could have an issue with the charge air pipes possibly leaking, or vacuum hose that has separated somewhere in the turbo control. A thorough visual nspection and possibly smoke testing would be needed to find where your loosing boost pressure causing the noise.
Feb 14, 2010 at 11:39 AM
