2003 Volvo XC90 engine overboost
100,000 MILES • 6 CYL • AWD • AUTOMATIC
SGAPEN
i have a xc 90 with a code, po234 engine overboost,
how do i go about, fixing this?
Jun 3, 2010 at 5:47 AM
JIS001
  • 3,412 POSTS
Smoke test the intake system. You have a leak somewhere in the turbo system. Could be the plastic charge pipe hoses down to a split open vacuum hose that controls the turbos. You could also have a stuck closed turbo control valve or it can be plugged up also?
Jun 5, 2010 at 1:25 PM
