2006 Volvo XC70 Wheel shake
2006 VOLVO XC70
50,000 MILES • 6 CYL • AWD • AUTOMATIC
FLDENNW
I am getting front end shake at highway speeds, but only when accellerating. As soon as I take my foot off the pedal, the shaking stops. While at cruising speeds the ride is smooth. There is no abnormal tire wear, front or rear. A front end alignment tech suggested that it may be a drive train issue (covered by warranty) due to the accelleration only aspect. The dealer is suggesting a possible wheel balancing problem. Neither has examined the car. Any other suggestions?
Jul 10, 2009 at 6:30 AM
JIS001
  • 3,412 POSTS
If your car is still under warranty then you should take itin to the dealership and have them check it out. If you had a wheel balance problem then you should feel the vibration whether or not you accelerate or not. Normally if it shakes under acceleration it usually means you have a bad axle. So just take it in to Volvo a have them check the problem. You may also want to go with the tech on a test drive to show them your complaint. Good luck.
Jul 14, 2009 at 4:58 PM
