2004 Volvo XC70 gas tank
29,000 MILES • 6 CYL • AWD • AUTOMATIC
MANUSAREEN
When I try to fill gas, it stops the nossel flow after every 1-2 gallons. I have tried at different gas stations and this happens all the time. It seems like the sensor thinks that the tank is full and breaks the flow and sometimes even throws some gas out. Can you tell me what might be causing this?
Feb 6, 2009 at 7:24 AM
YASGER
  • 83 POSTS
The hose could be kinked from the insert to the gas tank on the car...
[quote:62b0c9254a="manusareen"]Engine Mechanical problem
2004 Volvo XC70 6 cyl All Wheel Drive Automatic 29000 miles
When I try to fill gas, it stops the nossel flow after every 1-2 gallons. I have tried at different gas stations and this happens all the time. It seems like the sensor thinks that the tank is full and breaks the flow and sometimes even throws some gas out. Can you tell me what might be causing this?[/quote:62b0c9254a]
Mar 21, 2009 at 2:57 AM
