2003 Volvo XC70 SURGING ENGINE REVS
2003 VOLVO XC70
86,000 MILES • 6 CYL • FWD • AUTOMATIC
BARRY FIELD
FIRSTLY : ENGINE IS 2.5LTR 5CYL TURBO
AFTER START UP & SELECTING A GEAR THE ENGINE REVS FLUCTUATE I.E. IDLES FAST THEN SLOW, AT 1 SEC INTERVALS. ONCE UNDERWAY THE ENGINE SEEMS TO PERFORM AS NORMAL, WITH NORMAL FUEL CONSUMPTION. THE ENGINE CHECK LIGHT STAYS ON ALL THE TIME. ALL OTHER GUAGES ARE NORMAL.
Oct 13, 2010 at 2:54 AM
JDL
  • 16,098 POSTS
Any applicable trouble codes? Some of the national brand autostores used to check codes for free. You can call and ask? A code might us in the right direction?
Oct 13, 2010 at 7:35 AM
JIS001
  • 3,412 POSTS
I would suspect a dirty pcv system and dirty throttle plate. You need a pcv gage to check for vacuum and if there is no vacuum then the intake manifold needs to be removed to get access to the pcv hose under the intake. The bolt is like a pcv valve, that will need to be cleaned out, a thin wire will need t be used to clean out the banjo and clear the pcv passage, and most likely the oil tra box will need replacing as well. Once the intake is out, remove the throttle body out and clean the plate. Now if you have potentiometer codes for the throttle, then most likely the throttle is failing. But like mentioned by JDL before, if you can get it scanned an post the codes on here it should help to try and point you in the right directon.
Nov 15, 2010 at 10:27 PM
