2002 Volvo XC70 Speaker Covers
RELYNNBECCA
  • 7 POSTS
2002 Volvo XC70
How do you get the speaker covers off the rear doors? Do you have to take the door panels off? It doesn't feel like they will just pop off.
Jun 1, 2010 at 7:21 AM
JIS001
  • 3,412 POSTS
Yes the door panel needs to be removed. You will see 6 plastic tabs around the outer part of panels. Push in the center pins and remove the tabs. And the inside of the handle you grab to shut the door is a little cover. Remove the cover to access the screw. Remove the screw and pull panel out just enough to see the inside. Disconnect the door handle cable and then remove.
Jun 5, 2010 at 1:47 PM
RELYNNBECCA
  • 7 POSTS
Thanks for the info!
Jun 6, 2010 at 6:26 AM
