2001 Volvo XC70 engine motor mounts
2001 VOLVO XC70
167,000 MILES • 6 CYL • AWD • AUTOMATIC
GSCHELL
we are trying to replace the motor mounts, having trouble getting the bottom front one out. How do you remove the old one?
Jul 11, 2010 at 11:57 AM
JIS001
  • 3,412 POSTS
It would help if you had a hoiste? To replace it you need to remove the upper beam out of the way. Remove the engine mount bolts. Remove the bolts for the lower torque rod. Using a jack under the transmission jack up the engine. Remove the engine mount and install the new one.
Jul 14, 2010 at 7:51 PM
