2000 Volvo XC70 Random clincking noise
170,000 MILES • 6 CYL • AWD • AUTOMATIC
COURTNIER
I have a random clicking noise that seems to be coming from the front of the car. It is not dependent on turning right or left, Increased speed will increase the amount of the clicking - when present. I checked the front driver side brakes (thinking that I could have a loose clip or something) however, it all seemed solid and in order.
The clicking doesn't happen all of the time.
Any ideas?
Jun 26, 2009 at 9:55 AM
BUDDYCRAIGG
  • 2,262 POSTS
You asked for an idea.
How about the rusty, out side edge of a rotor
Jun 26, 2009 at 6:13 PM
COURTNIER
Thanks for the response back. The rotor looks fine. What I'm wondering is, could it be a CV joint that is only affected as power shifts to that wheel? Or, would a CV make a constant noise?
Jun 27, 2009 at 1:36 AM
JIS001
  • 3,412 POSTS
Do you think the clicking maybe coming from under the hood? Or are you sure it is coming around the susspension side? If this is all wheel drive you may want to have the drive shaft inspected as well?
Jun 27, 2009 at 4:41 AM
