2000 Volvo XC70 noise
2000 VOLVO XC70
MIKE DIXON
Suspension problem
2000 Volvo XC70 All Wheel Drive Automatic 97000 miles
There is a very pronounced noise coming from the right side and if feels like it is the shock or spring. It is a noise like a rusty spring but it only is very noticeable in cold weather when you hit a bump or go over a rut. When the outside temperature it is over 60F there is no noise. Car seems to run fine straight and smooth at all times. No jerking on the steering wheel at any time.
Mar 1, 2009 at 11:39 AM
YASGER
  • 83 POSTS
yes,it does sound like a strut or shock.
[quote:7ae64dda43="Mike Dixon"]Suspension problem
There is a very pronounced noise coming from the right side and if feels like it is the shock or spring. It is a noise like a rusty spring but it only is very noticeable in cold weather when you hit a bump or go over a rut. When the outside temperature it is over 60F there is no noise. Car seems to run fine straight and smooth at all times. No jerking on the steering wheel at any time.[/quote:7ae64dda43]
Mar 21, 2009 at 2:55 AM
