Electrical problem
2000 Volvo XC70 4 cyl All Wheel Drive Automatic
I had this bomb diagnosed and it was the speed sensor. On the way home from the shop, the engine light went on again. This car can't run without it.
I keep getting the ABS light and the brake light on together and then the speedometer stops working. As soon as they go out, the speedometer starts working again. I also get the ABS light and the light with the triangle and a car skidding in it. This doesn't affect anything like the other combo. The car also runs as if it were being held back. The engine runs fine. It's getting hard to get the car to start too. Nothing else showed up on the diagnosis.
Should I push this one oveer a cliff or is there hope out there somewhere? Thanks.
Jul 28, 2009 at 9:10 AM
