1999 Volvo XC70 head gasket
GREG CHILCOTE
Engine Mechanical problem
1999 Volvo XC70 All Wheel Drive Automatic 188000 miles
How do I change a cylinder head gasket?
Apr 23, 2008 at 12:21 PM
BLACKOP555
  • 10,386 POSTS
i dont suggest doing it if you have never seen it done or know how its done.
but if you want to, you will have to remove and disconnect all wires by the head and manfiold, then remove themanifold.
next step would be remove and park spark plugs and wires as to not damage them. then remove the valve cover and unbolt the heads.
pull heads off and theres your gaskets.
Jul 18, 2008 at 12:35 PM
