1999 Volvo XC70 cranks but no start
MDAUGHTRY
  • 1999 VOLVO XC70
Engine Performance problem
1999 Volvo XC70 All Wheel Drive Automatic 161000 miles
i turned the car off after driving aproximatley 10 miles was away from vehicle 20 mins when I returned to start it it would crank but would not start. There are no trouble code present. Timing belt was done at 103k where do I go from here?
Saturday, July 10th, 2010 AT 10:45 AM
What you need to do is determine if its a fuel or spark problem that's preventing it from starting-Do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, cap and rotor, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Saturday, July 10th, 2010 AT 5:30 PM
JIS001
  • 3,411 POSTS
Do you have gas in the tank? Sometimes one of the level sensors do fail so you may get a reading about having a 1/4 of gas when you are actually out of fuel? Start by adding a couple of gallons of gas and let me know what happens.
Sunday, July 11th, 2010 AT 12:08 PM
